Cisco Document Team
Community Manager
Community Manager
The Cisco Document Team has posted an article.
This article will explain different Power over Ethernet standards, list power requirements and compatible power supplies for Cisco’s latest AP series.
Know of something that needs documenting? Share a new document request to doc-ic-feedback@cisco.com
Your input helps! If you find an issue specific to a document, please let us know. Remember to provide as much detail as possible when submitting a request or feedback on an existing document including information regarding the section, area, or issue you had with the document and what could be improved.
You can provide feedback in a few ways:
See How Cisco TAC is transforming documentation and simplifying self-service in this blog
Rich R
That doc is 18 months old now so missing the latest AP models.
Will somebody be updating/maintaining it with new AP models?
@Rich R thank you for your feedback. I sent your comment using the feedback button in the document to have someone review.
We don't want to miss your input (and may miss a comment under a post such as this). If you use the Feedback button located at the right panel of the corresponding article it will be sent directly to the content authors or someone within their technology group to review.
 Hope this helps!
Rich R
Noted (and I often do submit feedback on docs), but the point is that you should be making sure docs are maintained and up to date *before* sharing like that.  No point publicising out of date docs.
