06-03-2020 08:24 AM - edited 07-05-2021 12:08 PM
we're set up an environment for WIFI auto-connection,
but met "802.1x 'txWhen' Timer expired for the station", could anyone help me to check the log what happened?
please refer to the attached file for detail.thanks.
06-03-2020 02:59 PM
Pls attached "show wlan <wlan_id>" output. Also what is the RADIUS server you used in this 802.1X deployment, I would check RADIUS server logs as well.
Also confirm what software version (show sysinfo) you running on WLC and what AP model in used.
Rasika
*** Pls rate all useful responses ***
06-07-2020 09:54 AM
06-07-2020 05:22 PM
thanks, Rasika, Rrudling
we're trying our best to get the log that you mentioned, it's hard to get from our customer side for some security reason.
