8500 WLC 10G AOC Compatability
Kevin McCormick
I know the 8500 WLC says that only 10G SR modules can be used.
We are looking to redo our network configuration and are looking at buying some SFP-10G-AOC3M= assemblies
They do appear to be 10G SR modules with a permanent cable attached.
We can not find these assemblies listed in the compatibility matrix.
I am wondering if the 10G AOC assemblies are considered 10G SR modules and will work with the 8500 WLC.
Saurav Lodh
Level 7
Level 7
SFP-10G-AOC3M Transceiver Model is for Nexus 3k series
Very disappointing these do not work.
abwahid
Level 4
Level 4
10G AOC  will not work with 8500 WLC
10G AOC
mohanak
Supported interfaces:
Interfaces and Indicators
  2 10 Gigabit Ethernet interfaces
  Small Form-Factor Pluggable (SFP) options (only Cisco SFPs supported): SFP-10G-SR, SFP-10G-LR
  LED indicators: Network Link, Diagnostics
  1 service port: 10/100/1000 Mbps Ethernet (RJ-45)
