capture traffic radius and acct ... I need your help!
Tiago Marques
I need your help ... I need capture all the traffic that goes from a wireless client 802.1x to AP and the AP to RADIUS and Customer .
I connected a computer to a switch port where the AP is connected and configured as follows:
monitor session 1 source int f0 / 1
monitor session 1 des int f0 / 12
but only see Radius packets between the AP and the server ... I could not see accounting communications or DHCP REQ by the customer .
7 Replies 7
George Stefanick
Is your AP autonomous or controller based?
is AP autonomous, cisco 1602i.
regards
If you are indeed sniffing the port the AP is connected to you should see all of this traffic. DHCP, Radius, etc. Do you have filters on your analyzer that may be preventing you from seeing this traffic?
I don't use any Filters ...the RADIUS server is a NPS of microsoft .
on the radius i have configured the accouting for Cyberoam ... but when I'm capturing the traffic , I don't see AP communication with Cyberoam ... but they have open communications ( active routes...for exemple ping OK)
i need configure a specify attribute on NPS for radius send USER-NAME in accounting packet?
I made a new test:
SW
monitor session 1 source interface Fa0/1 both
monitor session 1 destination remote vlan 41
CORE
monitor session 1 source remote vlan 41
monitor session 1 destination interface g7/5
but I do not see traffic (accounting) from ap to cybroam!
resolved.
problema with AP (1602i) firmware ... upgraded to version ap1g2-k9w7-mx.152-4.JB6
the config on access point:
aaa group server tacacs+ tac_admin
server 172.20.254.1
aaa group server radius rad_eap
server name 172.20.0.35
aaa group server radius rad_mac
aaa group server radius rad_admin
aaa group server radius rad_pmip
aaa group server radius dummy
aaa group server radius rad_acct2
server name 172.20.0.33
aaa authentication login eap_methods group rad_eap
aaa authentication login EAP_MTD group rad_eap
aaa authentication login mac_methods local
aaa authorization exec default local
aaa accounting network acct_methods2 start-stop group rad_acct2
aaa session-id common
dot11 ssid Public
vlan 40
authentication open eap EAP_MTD
authentication network-eap EAP_MTD
authentication key-management wpa version 2
mbssid guest-mode
interface Dot11Radio0
encryption vlan 40 mode ciphers aes-ccm
ssid Public
interface Dot11Radio0.40
encapsulation dot1Q 40
no ip route-cache
bridge-group 40
bridge-group 40 subscriber-loop-control
bridge-group 40 spanning-disabled
bridge-group 40 block-unknown-source
no bridge-group 40 source-learning
no bridge-group 40 unicast-flooding
interface Dot11Radio1
ssid Public
interface Dot11Radio1.40
no ip route-cache
bridge-group 40
interface GigabitEthernet0.40
no ip route-cache
bridge-group 40
interface BVI1
ip address 172.20.254.198 255.255.255.0
no ip route-cache
ip default-gateway 172.20.254.254
radius-server attribute 6 on-for-login-auth
radius-server attribute 8 include-in-access-req
radius-server attribute 32 include-in-access-req
radius-server attribute 25 access-request include
radius-server timeout 10
radius-server vsa send accounting
radius-server vsa send authentication
radius server 172.20.0.33
address ipv4 172.20.0.33 auth-port 1645 acct-port 1813
key 7 XXXXXXXXXXXXXXXXXXXX
radius server 172.20.0.35
address ipv4 172.20.0.35 auth-port 1812 acct-port 1646
key 7 XXXXXXXXXXXXXXXXXXXXXXXXX
I don't understand how I can see accounting packages in wireshark...
help me!!
