01-13-2011 03:45 PM - edited 07-03-2021 07:40 PM
Hey Guys,
I can't seem to get the SSID RadiusTest to work properly.
Windows PC's show "Windows was unable to find a certificate to log you into the network". Macs don't authenticate either. Radius server isn't seeing any requests at all. Radius server is working because we are authenticating other things to it.
On my test 1231, IOS is 12.3(8) JEB1.
And all help is appreciated.
Scott
version 12.3
no service pad
service password-encryption
hostname TKS-AP1231-ICTServices
enable secret 5 $1$Izyg$qXSRYpFDI9ZX6F50vDrku0
clock timezone K 10
clock summer-time K recurring
ip subnet-zero
ip domain lookup source-interface BVI1
ip domain name domain.com.au
ip name-server 172.16.###.###
aaa new-model
aaa group server radius rad_eap
server 172.16.###.### auth-port 1812 acct-port 1813
ip radius source-interface BVI1
aaa group server tacacs+ tac_admin
aaa group server radius infrastructure
aaa group server radius clients
aaa group server radius central_auth
aaa group server radius rad_mac
aaa group server radius rad_acct
aaa group server radius rad_admin
aaa group server radius rad_pmip
aaa group server radius dummy
aaa group server radius rad_eap1
server-private 172.16.###.### auth-port 1812 acct-port 1813 key 7 060D062F4B5D1B18045GHW1E0718
aaa authentication login eap_methods group rad_eap
aaa authentication login mac_methods local
aaa authentication login method_infrastructure group infrastructure
aaa authentication login method_clients group clients
aaa authentication login method_Central group central_auth local
aaa authentication login eap_methods1 group rad_eap1
aaa authorization exec default local
aaa authorization exec method_Central group central_auth local
aaa accounting network acct_methods start-stop group rad_acct
aaa session-id common
dot11 mbssid
dot11 vlan-name Conference vlan 150
dot11 ssid RadiusTest
vlan 18
authentication open eap eap_methods
authentication network-eap eap_methods
authentication key-management wpa
mbssid guest-mode
dot11 ssid Staff
vlan 17
authentication open
authentication key-management wpa optional
wpa-psk ascii 7 055E5F5E0555401B161003171928013C22272D6B6370
dot11 ssid Student
vlan 16
authentication open
guest-mode
mbssid guest-mode
wpa-psk ascii 7 02575102282A2323434F1B1D0C1915595A5C
dot11 network-map
dot11 arp-cache optional
username ########## privilege 15 password 7 ###################
bridge irb
interface Dot11Radio0
no ip address
no ip route-cache
encryption vlan 17 mode ciphers tkip wep40
encryption vlan 16 mode ciphers tkip
encryption vlan 18 mode ciphers aes-ccm tkip
ssid RadiusTest
ssid Staff
ssid Student
speed basic-1.0 2.0 5.5 6.0 9.0 11.0 12.0 18.0 24.0 36.0 48.0 54.0
no power client local
power client 50
power local cck 50
power local ofdm 20
channel 2437
station-role root
interface Dot11Radio0.6
encapsulation dot1Q 6 native
no ip route-cache
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
bridge-group 1 spanning-disabled
interface Dot11Radio0.16
encapsulation dot1Q 16
no ip route-cache
bridge-group 16
bridge-group 16 subscriber-loop-control
bridge-group 16 port-protected
bridge-group 16 block-unknown-source
no bridge-group 16 source-learning
no bridge-group 16 unicast-flooding
bridge-group 16 spanning-disabled
interface Dot11Radio0.17
encapsulation dot1Q 17
no ip route-cache
bridge-group 17
bridge-group 17 subscriber-loop-control
bridge-group 17 port-protected
bridge-group 17 block-unknown-source
no bridge-group 17 source-learning
no bridge-group 17 unicast-flooding
bridge-group 17 spanning-disabled
interface Dot11Radio0.18
encapsulation dot1Q 18
no ip route-cache
bridge-group 18
bridge-group 18 subscriber-loop-control
bridge-group 18 block-unknown-source
no bridge-group 18 source-learning
no bridge-group 18 unicast-flooding
bridge-group 18 spanning-disabled
interface FastEthernet0
no ip address
no ip route-cache
duplex auto
speed auto
interface FastEthernet0.6
no ip route-cache
bridge-group 1
interface FastEthernet0.16
no ip route-cache
bridge-group 16
interface FastEthernet0.17
no ip route-cache
bridge-group 17
no bridge-group 170 source-learning
interface FastEthernet0.18
no ip route-cache
bridge-group 18
interface BVI1
ip address 172.16.#.### 255.255.255.192
no ip route-cache
ip default-gateway 172.16.#.###
ip http server
no ip http secure-server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
logging history debugging
snmp-server view iso iso included
snmp-server community KingsRO RO
snmp-server community KingsWr1t3 RW
snmp-server trap-source BVI1
snmp-server location ###
snmp-server contact ############################################
snmp-server enable traps snmp authentication linkdown linkup coldstart warmstart
snmp-server enable traps tty
snmp-server enable traps entity
snmp-server enable traps disassociate
snmp-server enable traps deauthenticate
snmp-server enable traps authenticate-fail
snmp-server enable traps dot11-qos
snmp-server enable traps switch-over
snmp-server enable traps rogue-ap
snmp-server enable traps wlan-wep
snmp-server enable traps config
snmp-server enable traps syslog
snmp-server enable traps cpu threshold
snmp-server enable traps aaa_server
snmp-server host 172.16.###.## version 2c cisco udp-port 1620
radius-server host 172.16.###.### auth-port 1812 acct-port 1813 key ##########################
bridge 1 route ip
wlccp ap username wds password #################
wlccp authentication-server infrastructure method_infrastructure
wlccp authentication-server client any method_clients
banner login ^C
^C
line con 0
line vty 0 4
sntp server 172.16.###.###
sntp broadcast client
end
01-14-2011 12:26 AM
You configured your WDS to use empty radius methods. There's no much point to this apart from breaking your setup.
Remove all 3 "wlccp" commands. I suggest to have your normal radius working before you try and do WDS.
If behavior is still the same, then it means that the radius server has to get a request if the clients are proposed EAP-TLS and they are looking for a certificate to authenticate with ...
Did you pre-configure a profile on the client ? Did you configure them for PEAP ? EAP-TLS ? Which method do you allow on your radius server.
Nicolas
08-02-2012 10:42 AM
Also you only have bridge 1 route ip, you would need bridge 16 -18 protocol ieee added to match your other sub-interfaces.
