WLC and windows radius issue and another problem
Hi everyone.
We have a problem with a costumer wireless infraestructure which has a WLC using a Windows 2003 radius server. for authentication.
The users can't connet to the SSID from monday. Anything haven't been changed and the configuration is correct.
I think its a client problem because the clients who use Linux can connect.
Any idea?
I have attached a debug dot1x events when a windows client try to connect.
We have another problem with another SSID using local wpa2/pkm/ascii authentication..
This SSID is used for smartphones. The clientes who use Android can connet, the clients who use IPhone can't.
Is this a cospiracy? xD
Thank you for avance.
Best regards
Stephen Rodriguez
for the debug you attached, I see the client send an EAPOL start message, after it gets the Identity request.  It seems to move beyond that, and then
Jul 30 15:36:47.396: 18:3d:a2:65:bd:54 Processing Access-Reject for mobile 18:3d:a2:65:bd:54
I'd take a look at the IAS logs to see why this particular client was rejected.
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
HTH,
Steve
Thank you for the answer
This happend to any client.
I'm not familiar with IAS, do you know where can I check the IAS logs?
Thank you.
Best Regards
If I recall correctly it should be the system log. You'll see messages marked IAS.
Steve
HTH,
Steve
