config ap cert-expiry-ignore {mic|ssc} enable
daswann
We found a couple of old 1141N AP's in our network that were not associated with the controller. Upon investigation I found that the MIC had expired. We are currently running 8.3.133 on the controllers. If this command is used in the shot term, (until I can replace them with new models)  it will only be relevant to AP's with an expired MIC and not affect any other AP's from what I have read correct? Also would this leave them open to man-in-the middle attacks? Thank in advance!
marce1000
 - Yes, that is correct, those with valid certs (not expired) will not be prone to man-in-the-middle attacks.
 M.
8 Replies 8
marce1000
 M.
Thank you M. just wanted to make sure. I will be replacing the access points tomorrow so I won't need to use the command but wanted a second set of eyes on it.
Hi Marce - Do you know if the older APs "with expired" certs will be vulnerable to MIMs?
thanks
Hello Marce,
Hello, I have a Cisco WLC 2504 with version 7.6.130.0 but both commands below are not available:
Command for Version 7.0.252.0:
config ap lifetime-check {mic|ssc} enable
Command for Versions 7.4.140.0 and later:
Please help
Thank you,
- You need at least 8.3.x for that.
M.
RHEA LINN
How do you determine the MIC on the expired AP?
      AP_CLI#sh crypto pki certificates
         Look for the line containing end date
 M.
Does the AP check?
Does WLC check?
If I use config ap cert-expiry-ignore mic enable on WLC 5520 model, is AP OK in MIC authentication?
