MSE Enhanced WIPS Engine don't show
Hello ,
I'm following this guide
http://www.cisco.com/en/US/docs/wireless/technology/wips/deployment/guide/WiPS_deployment_guide.html
but I can not see
feature?
I have this licencse
wIPS Local Mode APs
Emiliano
5 Replies 5
aqjaved
Level 3
Level 3
Cisco wIPS solution offers flexible and  scalable, 24x7x365-based full time wireless security solution to meet  each customer's needs. This document will cover the wIPS security  solutions that are provided as part of Cisco Unified Wireless Solution.  Depending on your deployment, there is a solution to meet your security  needs, starting with the base Wireless LAN Controller (WLC), followed by  the WLC and MSE, and finally the WLC, MSE, and CleanAir enabled access  points.
Please check the below link which can helpful for you in  configuration:
http://www.cisco.com/en/US/docs/wireless/technology/wips/deployment/guide/WiPS_deployment_guide.html#wp57176
I had already written the link that I read is the same. But i haven 't
Did this ever get answered?
I think the screenshot above is old or not correct, the APs must be in Monitor mode to get the Enhanced WIPS Engine. Have you tested that?
Cheers,
Ric
Please rate helpful / correct posts
I have, it still does not show up are even when I turn the AP into Monitor Mode.
