05-07-2012 01:45 PM - edited 07-03-2021 10:07 PM
If I have a WLAN on a particular VLAN x and I set the multicast VLAN to another interface on the WLC that is on VLAN y, would that snoop the multicast traffic for bonjour and put it on VLAN y? I know that is not necessarily the purpose of the multicast VLAN but would provide a nice way of dealing with IPADs on multiple WLANs.
Thanks.
05-07-2012 01:51 PM
I don't think that would work since the iDevices really needs to be on the same subnet. Have you got it to work like that?
Scott Fella
Sent from my iPhone
05-07-2012 01:54 PM
I have not tested it yet. I wasn't sure exactly what it would do with the TTL of 1, but didn't know if anyone else had tried it.
05-07-2012 01:59 PM
I've used that for video streaming, but for iDevices I have to put them in their own subnet.
Scott Fella
Sent from my iPhone
