NAC - Allocating Vlans to host ports based upon AD group membership
dave.chadwick
Does anyone know a link or where I can get information about the following:-
My customer requires the hostport on an access switch to be allocated to a specific Vlan based upon the AD Group that the user is a memeber of ?  I am planning to setup NAC in a Real Gateway OOB deployment, using an ACS 5.2.  I was initially thinking that the initial authentication server would be the ACS and then the AD, which using group mappings within the AD, I could then assign the user to a specific ACS group and then pass a Radius attribute back to the NAC manager for processing - the problem is I'm unsure if this is even possible ?  Any Help would be appriciated. Thanks.
Federico Ziliotto
Hello David,
Nice to hear back from you on CSC ;-)
What you are looking for may be the mapping rules for authentication servers:
http://www.cisco.com/en/US/docs/security/nac/appliance/configuration_guide/48/cam/m_auth.html#wp1158789
Hope this helps,
Fede
If  this helps you and/or answers your question please mark the question as  "answered" and/or rate it, so other users can easily find it.
Vinay Sharma
Level 7
Level 7
Hi David,
Please mark this Question "As Answered" if you have received the correct info from Fede.
thanks,
Vinay
Thanks & Regards
