Scripting on a WLC
gorazd863
Community Member
I would need to generate a new shared key for a Guest-Wi-Fi and send it to defined e-mail addresses every week.
Does anybody know, is it possible to script it on a WLC?
Gorazd
Surendra BG
AFAIK WLC doent know how to execute the scripts.. I think this is not possible on WLC.. However WCS may help you in emailing the credentials.. here is the link for htat, if you hav a WCS you can use this..
http://www.cisco.com/en/US/docs/wireless/wcs/7.0/configuration/guide/7_0manag.html
lemme know if this answered your question..
Surendra
Please dont forget to rate the posts which answered your question and mark it as answered or was helpfull
Surendra BG
This is kind of a way to do it via expect under linux
The script was originally cobbled to pull info from the WLC for import into MRTG or Cacti
I am still waiting for Cisco to slap an IOS-like interface on the WLC !
USE AT YOUR OWN RISK
First script:
wlc.exp
#!/usr/bin/expect
set router [ lindex $argv 0]
set username [ lindex $argv 1]
set password [ lindex $argv 2]
spawn ssh $router
set timeout 10
expect "(yes/no)?" {
send "yes\r"; exp_continue }
expect "User:"
send -- "$username\r"
expect "assword:"
send -- "$password\r"
#expect "Controller)"
#send -- "show client summary\ry\ry\r"
#add in your command here with same syntax                          # this is where you would run your command
expect "Controller"
send  "save config"
expect "(y/N)"
send -- "n\r"
expect "Controller"
send "logout\r"
expect "(y/N)"
send -- "n\r"
# you will need the above two lines after any command that expects a yes or no confirmation
expect eof
Second file:
#!/bin/bash
#Info: Peter Kok(pk21-at-hotmail.com)  <---- original author
path_to_scriptsdir=/usr/local/bin
# where you place the script
router="$1"
username="$2"
password="$3"
output=$($path_to_scriptsdir/wlc.exp $router $username $password)
#   associated=$(echo $output|grep -o Associated|wc -l)
#   probing=$(echo $output|grep -o Probing|wc -l)
#   authenticated=$(echo $output|grep -o Yes|wc -l)
#   echo -n "asso_clients:$associated prob_clients:$probing auth_clients:$authenticated "
exit 0
