Wlan schedual
meirelyahu
Is there an option to limit WLan network to be enabled only on specific time period? ( 9:00 to 17:00 ). I'm using WLC4404 version 5.0.148.0
thank you
Meir
7 Replies 7
sschmidt
Currently this feature does not exist. You can schedule a radio interface to be on/off on a schedule but doing the same with an entire wlan is not possible.
ok,
How do I schedule the radio interface?
Meir
Thank you for your help!
ericgarnel
Level 7
Level 7
If all the radios are on PoE switchports, you could write a script that turns off the switchports and run it through a cronjob
talmadari
While using only the WLC (controller) you can't schedule work time for the WLAN.
If you will use the WCS you can schedule to enable specific (or all) SSID's on a specific (or all) AP's.
I have WCS.
How can I Schedule specific SSID?
