4x WAP4410N internet connection question
We have 4x WAP4410N accesspoints 1 AP & 3 Repeaters, this works perfect. The situation at the moment is that the internet connection is plugged in with a cable on the AP but the question is that if it's possible to plug the internet connection into one of the repeaters?
After that are we still able to use the internet over al four accesspoints?
Thank you
Maikel
jasbryan
Level 6
Level 6
Maikel
I would leave it the way you have it configured now, since your 1st AP is your MAIN and the others are having to repeat/ and broadcast. I think it might cause some issue later if you attempted internet connection on the repeaters.
Jasbryan
Cisco Support Engineer
