WAP4410n authenticating to Active Directory
Hello all,
I have a WAP4410n which I'd like to authenticate users against our corporate active directory. I would like to know how to achieve this - whether we require a dedicated RADIUS server, whether AD has a RADIUS engine which can be used, etc. Also, what would the pros / cons be of this setup versus using a WPA2 password?
regards
Malcolm
jasbryan
Level 6
Level 6
HI,
Then only configuration you need to do in the WAP4410N is set the security mode to WPA2 enterprise,
Enter RADIUS server IP address ••à
RADIUS port number (1812)
Shared Secret (phase of RADIUS server key)
Key Renewal Timeout (keep at default setting)
This is all the configuration you will need to do in the WAP4410N, All other configuration will be done on the Microsoft Server and client Side. Many customer calls for support when they are trying to use RADIUS with the AP and the AP is only passing all wireless traffic to RADIUS server (It will be a RADIUS problem not AP problem). The WAP4410N is only providing wireless connection to the client at this point. It’s not doing any authentication all is done between Client and RADIUS server
SEE MICROSFOT FORMS FOR THE CONFIGURATION OF RADIUS SERVER AND CLIENTS.
Cons:
For most users (Very difficult to implement)
Can be Complex implementation
Pros:
Auditing, seeing who is logged on and when
Scalability over a Wide network.
All users don’t’ have same security key (authentication via user name and password)
Greater Security
Central point of administration
Jasbryan
Cisco Support Engineer
Dear Jasbryan,
Thank you so much for this information, which has been hugely valuable. As always, I shall post a closure to my request once I get this solution completed.
Warm regards
Malcolm
