05-01-2011 06:35 PM
I have the following equipment:
Cisco 871W router
2x WAP 4410N APs running 2.0.3.3
I currently have 1 AP connected to the router via copper. The AP to AP link is over 802.11. I have attached a diagram reflecting the current topology.
The AP-to-AP link will come up utilizing B/G/N mixed mode; however, the connection is basically unusable. About 30% of the traffic is dropped, while the packets that do make it have a consistently volatile latency, anywhere from 15 to 1500 ms.
I have had success using G-only and B/G mixed. The link is stable (I have had the best results with B/G). The problem is, I didn't buy the 2nd 4410N to run the G protocol. I would like to connect the APs running either B/G/N (hopefully negotiating to N) or N only. I am wondering if there is a certain configuration I can utilize (perhaps using WDS repeater or bridge versus Wireless Client/Repeater?), or a firmware upgrade set for release that can make this happen for me.
Any help would be appreciated!
Matt
CCNP/DP
05-01-2011 09:57 PM
I have a similar set up:
rvs4000 -> wap4410n (ap) -> wap4410n (wds repeater) using b/g/n and wpa2-personal
One or the other wap4410n would hang every few hours using the latest firmware unless I switched to wep, which allowed them to work for at least a couple of days without problems.
I'm currently using beta firmware (you need to open a case with cisco to get this) and with wpa2, one or other of the wap4410n "only" hangs every one or two days.
