Hello! This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful. Virtual Assistant- Discover support content and options for your gearSupport page index - Contains a ...
Hi,I bought an Access point (WAP4410N) few days before, Problem is, its drops signal after few hours OR after couple of hours. I changed the channels two to three times due to there are other wireless networks around my location. Version of firmware ...
Hi,I have 3 AP 541N where I work. I initially installed one, which worked well, but I could get the range I needed so added a further 2. I have created a Cluster and joined all the APs to it. I now have an issue where the network keeps dropping off, ...
Hello,we want to use a WAP 2000 Box as repeater of an AP541n. Do naybody know this is possible or not?Which Cisco AP boxes are compatible to act as repeater on a AP541n?Any help will be appreciated. Thanks.
Hello,I want to use 6 x WAP200 to create a small wireless network with the use of PoE.Can I connect the 6 WAP200 on the Cisco SF 302-08P?If not can I use 2 x Cisco SD208P?Or do I need a other switch to do the job?Regards,Patrick
Hi,I was checking out some Small business series wireless IP Phones models. There is very less choice available.... the only model I could find details was WIP310.http://www.cisco.com/en/US/products/ps10041/index.htmlBut even this is end of sale.I wa...
Hello, I'm new to Cisco devices.I have WAP4410N and AP-1131AG for the school lab's Access point.First, WAP4410N doesn't make connection to wired network.There's no DHCP server in our school and uses below :192.168.x.x ip address255.255.0.0 Subnet192....
We have two WAP2000's in our offices which we roam between depending on which office we are in. Lets call them Access point A and Access point B.Both are firmware 2.0.4.0 and have seperate IP addresses. Both are set up with two SSID's and VLAN taggin...
All - what's the best antenna arrangement for wall mounting the WAP4410N?I see pictures of the antennas for desk mount but nothing for a wall or ceiling mount.Should I just fiddle with them and see what works best?Any suggestions greatly appreciated....
We have a new deployment where we have 5 total 7921G wifi phones connected via 2 AP541n access points, one connected to a ESW520p switch and then to the UC540 and the other connected directly to the UC540. The wifi phones are intermittently giving n...
We have a WAP2000 that supports a few wireless users in a shop environment. Users authenticate using RADIUS. Users connect without issue and can browse the Internet.The main local network uses a Cisco 800 router to connect to the Internet via DSL a...
Attached is a screenshot of a small bug in the System Up Time. It shows Hour:Day:Sec where it should show Hour:Min:Sec.
Hi There,I have configured an SSID using RADIUS as authentication from a win2k8 R2 DC. Connecting from a domain-joined machine with a user already logged in works fine, but the issue we have is from non-domain machines (including iphones & blackberri...
Hi,I'm trying to find the maximum number of mac filters that are supported on the Cisco 4410N access point. The datasheet says that it supports mac filtering but does not indicate the maximum number of filters. Can anyone help? Thanks.tc
Hello,I'm having troubles with AP541N in clustered mode.The problem is that clients connects successfully but get disconnected after seconds without any visible reason.The AP541N is configured to authenticate the clients against a Symantec Network A...
Can anyone assist me on setting up the above Router on 2 Mac Computers on our networkThis mac's are a duel system (using Fusion) & the router works fine on the Windows side.I have airport turned on but I am unable to access the network or internet fr...
