04-23-2012 09:48 AM
Hi all
I hope that you can help me , tried to find the answer by looking at brochures etc. but could not find the answer.
- My objective: have 2 Access Points at home which extend the reach of my current .11n network in a seamless fashion when I move around without ever losing the connection
- My base setup: single wireless .11n router
- What I tried so far:
- power line adapters to build a wired network
- one of the power line adapters has a built-in .11n Access Point
- set the AP to have same SSID / WAP key as the router
- hoped that PC would seamlessly switch from Router to AP seamlessly
- What is the issue:
- yes the PC can switch from one to the other, but first it needs to eg lose the connection from the router, look around, and then connect to the AP
- so I get disconnected for some seconds before connecting again
There has to be a simple solution to this (eg what I experience at the office every day )
Note: from what I read a Wireless Repeater is not a good solution because it halves the bandwidth (and even worse if I were to have 2 of them)
Can you please help me with what would be the simplest solution to this objective?
Thanks very much in advance
Henri
04-23-2012 10:25 AM
Hello Henri,
Currently in the small business line of wireless we do not have a true seamless roaming solution. This is a feature support by our enterprise devices. More precisely, a wireless LAN controller is needed.
I have seen with several of our APs that when moving from one AP to the other that only 1-2 packets are dropped during the transition. This however is an ideal amount of loss and the normal is in the range of 4+ packet loss.
04-23-2012 10:58 AM
Hi Robert
thanks very much for your advice.
This sounds actually a lot better than what I experienced which was lose connection for several seconds. Am I right in understanding that losing 4+ packets would actually not be noticed by the user and the connection would not appear to be broken?
Henri
04-23-2012 11:35 AM
The disconnect and reconnect would not be noticed by the user if all they are doing is roaming. However, for applications, streaming and voice, there would be a noticeable effect and could cause problems. It is not recommended for anything that requires a constant connection.
Also this is only a test in a small business enviroment that would be using 1-2 switches. If you have a large network, it could take a considerable time for traffic to be redirected.
For use in a home network with only 2 APs, the impact should be very small.
04-23-2012 12:45 PM
Thanks. Which is the simplest (but performing) equipment/model you would then recommend to get please?
04-24-2012 06:59 AM
Currently you have a few options. I have found this document which provides a lot of detail between the available models. Also to note, the WAP121 and WAP321 have just been released but are a great addition to our wireless devices.
04-24-2012 09:25 AM
Thanks Robert, I get an error message when trying to access the file on the link:
Forbidden File or Application The file or application you are trying to access may require additional entitlement or you are trying to access a file with an invalid name. Additional entitlement levels are granted based on a users relationship with Cisco on a per-application basis.
04-24-2012 09:41 AM
Sorry about the problem. It appears that it is listed as a partner resource. I went over the key features and I would recommend the WAP121 or WAP321.
The WAP121 has a 10/100 port with small usage in mind.
The WAP321 has a gigabit port and can be used with 2.4ghz or 5ghz channels.
If you are using this for your home connection the WAP121 should be enough.
