Hello!
This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful.
Virtual Assistant- Discover support content and options for your gearSupport page index - Contains a ...
Dear community,We are running WLAN using WPA2-enterprise with AES & IAS server.Mostly we are using AP's 1131 and Cisco WLC 4400.I added on a new location 2 AP 1142G and since the installation I got 3-4 clients having regular disconnections...Basical...
Hi, I recently bought a Cisco RE1000 wireless repeater to boost the wireless signal to my garage office. Since then the signal has been intermittent, fluctuating between strong and weak signals, sometimes dropping off completely. Today I finally u...
Dear, I would like help from you, because I have a problem and I can not detect. I have six devices installed in the WAP model 4410N on two different floors, and a third on each floor. Both are with the same SSID, but when I'm walking him on a quest ...
Hello, allI need to use the Radius in WAP121, but I found there is no field to change the port, only the field to input server's IP.The default port for Radius is 1812/1813, but my server is in our head quater and the port is the old port 1645/1646.T...
After doing a pre-sales chat with Cisco rep about my needs and budget he suggested the WAP321 and I purchased 4 and a Cisco POE 8-port switch. I have all 4 spread accross the building (small hotel with restaurant). Each is wired with power and data v...
Hi Support; I purchased a Linksys WAP200E Wireless-G Exterior Access Point – PoE and a HGA9N (9dBi) High Gain Omni-Directional Antenna through CDW Canada about three (3) years ago in April/2009. The first year it worked...
Hello,I just purchased a WET200. I understand it will transmit on one antenna and receive on two antennas. With this WET200 I observe only one antenna will receive. If I disconnect the left antenna and do a site survey, the various signals are exc...
I'm a tech at a local business in my community and I was brought a WAP200 that was giving a client some issues. I've been told the first thing to try is to update/reinstall the firmware. I have the newest firmware file downloaded and saved, and I hav...
Hi Everyone,I've just come across a situation where the customer requires to have their 300 different VLANs (they got 300 stores across AU) to be mapped to the same SSID. I know this is doable by creating an interface group on the WLC that contains a...
Although it does accept it in the setup wizard, you cannot change it in the vap list later on, it will throw a popup telling you there's an invalid character.Anyone's got a solution? I'm running firmwarte 1.0.0.3
Hello expertsWe recently bought 15 WAP321 units to build a Wireless Network in our company and because security is important to us, we wanted to change the Password of the wlan0 interface every week over SSH. Sounds easy and is easy when you get used...
I just set up a new wireless environment for my company using the ACS 1121, 2-5508 WLCs, with about 30 LWAP spread out over 10 different remote sites. We have 2 SSIDs, one is secured using PEAP, the other is set up using web auth for auditors and ven...
In the marketing info, the unit is shown wall mounted. Right now, I have 2 WRT54Gs wall mounted and I have always suspected that the wall mounting was the cause of poor coverage. The Linksys has omni directional antennas while the WAP21 has directio...
Hello to all.I had bued a WRP400-G2 device today and found 3 problems here (after upgrade firmware to latests). But biggest problem is that I can't open a bug case in TAC becouse I bued device from reteiler and have only one year warrenty. Is it poss...
