I have 12 WAP551's setup on a VLAN10 with the ip 172.16.0...... I used findit 2.0 to do the initial setup and was able to do the configuration though there. Once I set them up and put them on the VLAN10, I'm no longer able to access it through findit or through the ip address. I can see them listed, but they all have a yield sign next to them saying that the IP address does not match local subnet and may not be reachable. I tried to use VMWARe and change the ip settings to connect but was not successful. The only way to access the AP's is to connect a laptop to one of the VLAN10 ports and change the IP address of the laptop to the one configured on the access point VLAN10. I plan on connecting 12 more WAP551 and was trying to see if there was another way to connect to the ap's without having to connect a laptop to a switch and changing the ip address. Thanks in advance.
