Hello! This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful. Virtual Assistant- Discover support content and options for your gearSupport page index - Contains a ...
Hi Cisco, I m using Cisco WAP321 Device for Wireless connectivity. wireless access provided through MAC filter policy. Now 3 routers are connected in single cluster, but issue is- after 2-3 days, some mac address entry is deleted au...
Hello I can not create an account Find it
Hello Please confirm me the bellow ; 1- Cisco Outdoor 1530/1560 is it compatibile with the Cisco wireless controller 2504 ? 2- How will be the performance in a very hot envirement in summer outdoor in Kuwait Weather ? 3- what is your advice for ...
Hi, in our lab we have a WAP150 an wich we tried to enable more than 2 VirtualAP per radio.But as soon as you enable the 3rd network on either radio, there is no network broadcasted on both radios - the whole WAP150 is useless then. I've tried sever...
Hello Community, We have wireless network in our small office and works fine. Employees connected to the wireless LAN are on VLAN 30 and no issue. Wireless controller connected on port GE10 of the switch which is configured as trunk and VLAN 30 as Un...
Hi, Can you please help why my acces point 700i break internet connection to IOS device after laps of time 20 or 30 min. my configuration: version 15.3no service padservice timestamps debug datetime msecservice timestamps log datetime msecservice ...
Ok, so i have call customer service only to get hung up on! So i am still left with un-answered questions.... Some one please help. So I have a WAP121 Wireless- N access Point with PoE. I had to hit reset. If i am to go on my phone to WI-FI... The...
I have a WAP321 which I'm connecting to it with a crosswire. I've done multiple factory default resets and can web to the login page but when I use the default username and password I cannot get in to the configuration page. Any idea what could be wr...
My Cisco Small Business Wireless Access Point frequently refuses new wireless connections after working for about 2 or 3 hours unless i reboot. I observed this issue after i upgraded the firmware version to 2.0.7.8 i have tried power it with PoE and ...
Hello, I have 12 WAP551's setup on a VLAN10 with the ip 172.16.0...... I used findit 2.0 to do the initial setup and was able to do the configuration though there. Once I set them up and put them on the VLAN10, I'm no longer able to access it through...
HI . i have an controller 5508 running with 200 AP lic and the customer need to add 300 access points more so i will change the controller to 5520 my question is can i move the existing lic on 5508 to the new controller 5520??? Thanks
Hello There, On a WAP131, I am seeing below entries in the log-file, which start being populated roughly 6 hours after a power cycle. Firmware 1.0.1.4 (latest version) Time Stamp Severity Service Description Mar 29,2016 12:00:28 notice ...
Dear Concern, I have purchased three small business WAP321 without any power adapter and POE injector. basically there is no adapter and POE injector comes with it, i had to buy separately TENDA POE injector which is available in my country Banglades...
Hello, I own Cisco WAP571 Wireless-AC/N Premium and I try to set ACL. I want to block all trafic except http. In ACL >> ACL Rule, I had new ACL with ACL Name : MyACLIn MyACL, I had new rule with Action : Permit. I swtiched off Match Every Parcket.I...
Hi, I was programming my WAP4410N remotely thru VPN and by mistake I enable the web configuration option. I know the device IP and I know the ID and Password to access to the configuration but when I try to connect thru Web give me an error and I ca...
