Showing results forĀ
Search instead forĀ
Did you mean:Ā
CISCO 5508 AP LIC MOVE TO 5520
osama shalaby
HI .
i have an controller 5508 running with 200 AP lic and the customer need to add 300 access points more so i will
change the controller to 5520 my question is can i move the existing lic on 5508 to the new controller 5520???
5 Replies 5
Leo Laohoo
5508 to 5520?  Yes, you can.
thank you Leo , but how can i do that?
Send an email to the Cisco Licensing Team with the following details:
1.  Your CCO login;
2.  5508 serial number;
3.  5520 serial number; and
4.  Brief description on what you're trying to accomplish.
thank you i do appreciate
Thank you for taking the time to rate our posts.  :)
