08-30-2021 06:33 AM
Dear Wireless Experts,
I had tried to make the factory reset a AP (AIR-CAP3602I-N-K9) and I pressed over the time on MODE button.
Now, I boot the AP every time and the console is only showed as Ranma. Any idea to reset it back to normally?
08-30-2021 06:40 AM
Check Baud Rate.
Try change the Flow Control setting.
e.g. XON/XOFF
08-30-2021 06:47 AM
I connected the Console to the other same of model AP, that is normal
08-30-2021 06:49 AM
I changed the Xon/Xoff Flow control to be NONE, that is not for this AP also
08-30-2021 08:45 AM
Finally, I got the issued AP, that was showing up Blinking red and blue > Flash file system failure.
How to fix it on Flash file system failure's AP?
11-05-2021 07:09 AM
M.
11-13-2022 04:35 PM
couldn't access your link ...
