Hello!
This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful.
Virtual Assistant- Discover support content and options for your gearSupport page index - Contains a ...
I have the cisco buniness 140AC access point and would like to use the Cisco Business Dashboard to connect them all. I would like to know how to get my Cisco Business Dashboard setup and add AP
Hi,Thinking about buying a couple of CBW150AX and/or CBW151AXM Access Points but was wondering how configurable the backhaul is. Has anyone tried them or specifically, has anyone tried configuring a wired backhaul for multiple CBW150AX units.This wou...
Hello, i just bought a cbw240 access point and i plug it to a cbs350 8port poe switch running cbs_ros_3.2.0.89. after configuring the admin account and ssid credentials it doesn't broadcasts the new ssid. i reset, restart and configure it about ten t...
I've got a bunch of Cisco Business Wireless 240AC Access Points connected on a local lan. There's a main network and several Vlans. All the access points are visible on the dashboard from the primary 240AC and generally everything works as expected.H...
I'm using a CBW140C access point. I've created my main network with no problem.
On the other hand, I would like to create a second network, separated from the LAN of the company, in order not to have access to the resources and peripherals of ...
Hello everyone,for the past few months I have been experiencing problems using some Google devices connnected to a Cisco 140AC access point.Specifically, the problems concern:1) Google Home Mini: the device connects smoothly to the AP, plays audio co...
Hi I have 6 of these, I have set up the first as master and updated firmware to latest. I add the second access point and it take 7-8 minutes and hooks up successfully and I can see in on the master web app and everything works good then when I add t...
Hello!
New 150AX access point - plugged into port on router as per documentation; device stuck in a red-green-red cycle for hours. Have reset device twice; tried different ports on router AND various other options including a different router in same networ...
Dear Wireless Experts,I had tried to make the factory reset a AP (AIR-CAP3602I-N-K9) and I pressed over the time on MODE button.Now, I boot the AP every time and the console is only showed as Ranma. Any idea to reset it back to normally?
Running 3 APs that I recently updated (manually) to 10.7.1.0. When trying to run a Check for Automatic Updates I get an error "ciscobusiness.cisco PING: Destination not accessible". Did the basic troubleshooting and is able to resolve cisco.com from ...
Does anyone have an decent examples of ACLs for a 145AC. For "Any" do you use 0.0.0.0/0.0.0.0 Want to restrict Guest WLAN users from certain local LANS but allow access to the internet. As soon as I turn on the firewall and uses an ACL it breaks. Loo...
Hi,I recently purchased a CBW140AC to replace a WAP150, as per compatibility matrix;https://www.cisco.com/c/en/us/products/collateral/wireless/small-business-wireless-access-points/eos-eol-notice-c51-744838.htmlHow do I get the CBW140AC to join the m...
