Aironet 1240 - Cannot Set Time
ken
I am attempting to correct the time on my Aironet 1240 AP.  However, when I attempt to update the setting and "apply" them, I am directed to an invalid "page", and the accesspoint will not update and accept the setting. There is currently an invalid IP address in the "IP or Hostname" field, and even if I attempt to disable SNTP, I am directed to the same invalid page.  I appreciate any help I can get.
apasillas
Connect to console whit a blue cable and usb adapter to yout computer.  use putty or other program to set a serial connection. The ap will ask for user an password, Usualy cisco if you never change the user o password. Then use the next commands
enable <enter>
conf t <enter>
sntp server (ip addres of you sntp server).
do wr me
end
exit
http://blog.router-switch.com/2013/05/how-to-connect-to-a-cisco-standard-console-port-rj-45/
