Wireless - Small Business
Stay connected on-the-go with our Wireless solutions, designed for small businesses to boost productivity.
Don't miss this Cisco Catalyst 8000 offer
Labels
Update - We have completed the relabeling project for the wireless board. We will be lifting read-only mode today the Sixth of May. Thank you all for your patience and feedback.   We are approaching our latest step in relabelling posts across the Sma...
CoreyP319 by Cisco Employee
  • 581 Views
  • 0 replies
  • 1 Helpful votes
Hello!   This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful.    Virtual Assistant- Discover support content and options for your gearSupport page index - Contains a ...
  • 2833 Views
  • 1 replies
  • 5 Helpful votes
Hi all,We are facing a issue with the WAP321.Our wireless clients are facing communication issues  We can see a high response times during the ping tests.LAN clients are working fine. the Signal level is excellent -30 dBMthe Noise level has a variati...
mukka by Level 1
  • 2751 Views
  • 7 replies
Good afternoon I have a problem with 4 access point wap 121 configured as ap 2 vlan (ssids), the problem is that repende not the ssid 1 shows that most teams mac, also I lose connection with connected by wifi printers, also in the same segment vlan s...
Hi There, Experiencing an issue where our AP541N-E-K9 are dropping some clients on the wireless.In the logs we have the following:Mar 9 14:23:47  info  hostapd  wlan0: IEEE 802.11 STA 88:63:df:6d:97:e0 deauthed from BSSID 68:86:a7:fe:07:80 reason 6  ...
cparker by Level 1
  • 976 Views
  • 4 replies
I purchased 2 WAP 321's and plan to use WDS for roaming/signal purposes. Correct me if I am wrong but this would be the ideal setup: WAP-01-Main wap connected to the wired LAN 1. Set a static channel of either 1, 6 or 112. Setup the SSID's/VLANs3. En...
HelloHere's my quick story:During firmware update of my Access Point the power were cut off so the device is bricked now (WAP4410N v2).I connected to Serial port and did recovery so the all leds blinks alternately (push reset and connect the power) F...
Hi,I'm using WAP4410N Access Point in my network. I'm able to login to it before resetting the Access Point using web based administration utility. But after resetting the access point to factory defaults I'm unable to login and my username and passw...
itsmesan1 by Level 1
  • 1167 Views
  • 1 replies
I just purchased a "Small Business WAP371" and it did not come with a 12V power supply. My question is can I use a CISCO Model DPSN-35FB A Power Injector Part #341-0212--01 to supply power to the WAP371?Please reply to ajmarcayz@gmail.com
ajmarcdds by Level 1
  • 938 Views
  • 1 replies
Hello, We have 6 x WAP321's setup via "Single Point Setup". We have enabled MAC Filtering and set to "Block all stations in list".We have added one device into this list and confirmed this replicates around all the APs. However, it doesn't prevent th...
support by Level 1
  • 896 Views
  • 2 replies
