AP500 connect external outdoor antenna
is it posible to connect an outdoor antenna to the AP540?
And if Yes, which ones will fit?
Many Thanks in advance.
@lex
Glenn Quesenberry
If you are referring to the AP541N, the antennas are detachable, however we do not specifiy/recommend any external or outdoor antennas for this unit.
Best Regards,
Glenn
Glenn Quesenberry
Best Regards,
Glenn
Glenn,
thanks for this info. So it's up to me to test this for myself.
@lex
Please post back if you find results...
