Hi jollyitsolutions, thank you for using our forum, my name is Luis I am part of the Small business Support community. I read your post and I suggest checking your configuration from the SSID, please try to use low security in order to try if your devices are able to connect, also you can follow this article about WDS, you can check in the link below.
http://www6.nohold.net/CiscoSB/Loginr.aspx?login=1&pid=2&app=search&vw=1&articleid=3046
Also I will give you other article about how to improve your wireless.
https://supportforums.cisco.com/docs/DOC-29821
I hope you find this answer useful
Greetings,
Luis Arias.
Cisco Network Support Engineer.
