03-16-2025 01:17 PM
I am stuck trying to add a wireless 150AX mesh extender to my home network. I can add it and it works as a wired mesh extender, but does not reconnect wirelessly when disconnected from the ethernet switch. I have tried resetting it and adding it as a wireless mesh extender, both with the web gui and the phone app, and it fails with both (times out). While it is connected as a wired mesh extender, I can't see how to change its settings to add the wireless network. I have searched and don't see any information on what to do if it fails to connect wirelessly. Thank you for any help you can provide.
Solved! Go to Solution.
03-16-2025 01:39 PM
check may be this guide help you :
03-16-2025 05:43 PM
Update -- I moved it and it did reconnect. I also restarted the primary AP. Everything seems to be working well. Thank you.
03-16-2025 01:39 PM
03-16-2025 02:20 PM
Thank you for your reply. I did review that guide, even though it doesn't list the 150AX, and read everything available before I posted. It looks like it might work this time. I disconnected the ethernet cable but did not unplug and move the AP to the other side of the house. It looks to be still connected. Maybe my mistake was not waiting long enough for it to reconfigure before moving it. I'll post back later after I move it and see if it reconnects. Kat.
03-16-2025 05:43 PM
