03-18-2025 11:12 AM
Good morning.
I need a help I'm tempted as Wifi to put here in the company simple thing, with option of VLAN ID more I'm not managing to find information, This Wifi has Cisco Business 240AC Wi-Fi Access Point | 8ac | | 4x4 | 2 GbE Ports | Ceiling Mount | Limited Lifetime Protection (CBW240AC-B) ?
Solved! Go to Solution.
03-24-2025 07:47 PM
Hello @MarcioCampos07280 ,
Information on this Product can be found at: Cisco Business 240AC Access Point.
I hope it helps !!!
03-19-2025 12:04 AM
The VLAN ID must be set to the corresponding vlan number associated with the WLAN ,
M.
03-19-2025 12:06 AM
M.
03-20-2025 06:16 AM
Hello good morning,
Are you trying to map the SSID to a specific VLAN?
03-24-2025 07:47 PM
I hope it helps !!!
