CBW151AXM not connecting to CBW150AX (Red, green, black led)
brauckmiller
First off, I have to say I am EXTREMELY dissatisfied with Cisco's supposed support.  I just bought this device and it is not connecting.  I did the usual google searches and nothing helps.  I watched the Tech Talk videos and followed the directions with no luck.
I called support since I literally received it today only to be told to go piss up a rope since I bought the device from a 3rd party (Amazon).
The issue I have is basically in the subject line.  I added the MAC address to the LOCAL MAC address ALLOWLIST on the CB150AX and saved my config.
I plugged the extender in about 5 ft away from the AP.
It boots up and eventually goes into the Red, Green, Black cycle.
I have factory reset the extender with the same results.
I see there are a couple ports on the side but have no idea how to access them.  If someone can direct me where I can download the user manual for this thing, I'd appreciate it.  Better yet, if someone can tell me how/where to upgrade the firmware on the extender, I have a feeling it would really help.
If I can't get this working, i'll just send it back and give it a 1 star review on Amazon.
I'm an IT professional with 30 years experience and I work in the vendor support world.  I find it extremely frustrating that Cisco can just blow people off like this because they are the 800 lbs gorilla.  That's horrible customer service.  I even asked if I could buy a support incident and was rejected.  Just sad.
marce1000
                 - Check logs on the device to see what is going on ,
 M.
Ok, I'd love to do that.  Can I plug in to the console and gain access to the CLI without any login creds?
If not, what are the creds?
Thanks!
Craig
brauckmiller
F*CK it...I'm returning this piece of SH*T.
Lack of manuals.
Lack of support.
Luck of caring by Cisco.
