06-20-2019 04:16 AM
Hi everybody,
When I configure the CHROMECAST ULTRA in our meeting room I have the following message: "Meeting room can be configured but it is impossible to communicate with him from your Iphone A slight modification of your wifi settings is maybe Help then offers me to disable access point isolation and enable UPnP functionality How does this work on a Cisco WAP121?
Thanks for your help
06-21-2019 02:50 AM
Dear Christophe,
The UPnP functionality is usually implemented on routers, so you may want to check your router for that setting. As for isolation, the WAP121 has a feature called "Channel Isolation" which is meant to isolate the connected wireless clients from each other for obvious security considerations. This option is located under Wireless - Networks - respective SSID.
10-01-2019 06:02 AM
We have a similar issue.
There are 4 Cisco WAP121 access points distributed in our office. The Chromecast connects on our wifi network through an Access-Point in the same room (i.e. AP-04). I was able to configure the Chromecast from within the room, but I can't seem to cast any media to it. Strangely, when I move away from the room and sit myself about 10 metres away from it the, signal on the Home app turns green and I am able to cast to the screen.
It just seems that when my android smartphone uses the wifi signal from a different access point than the one Chromecast connects to/through it does work, but not when both Chromecast and smartphone use the same access point.
Any ideas how to overcome this issue?
Johan
