Hello!
This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful.
Virtual Assistant- Discover support content and options for your gearSupport page index - Contains a ...
What are people replacing the WAP371 with? I have one in my house connected to a RV325. The WAP is failing but the RV325 is working fine. I'd like to replace the WAP with something new that will work well with my router but isn't Meraki. I'm looking ...
Hi,as described in the german quick guide, only the ethernet led is flashing quickly, seems like a bad image. Also checked with a sniffer, no traffic on the ethernet port. Thanks a lot! PID VID: WAP321-E-K9 V01 https://www.cisco.com/c/dam/en/us/td/do...
I have a couple of Cisco WAP371 wireless APs and there is an issue with Wi-Fi roaming with iPhones. My test. I called my wife in the other room. She answered on another AP using Wi-Fi calling and an iPhone7. I walked to the AP she was on and when my ...
I using nine Wap371 to setup Single Point, The 5ghz is no problem but when using notebook at 2.4ghz, it always down.How can I make it stable and faster?WiFi user around 180(include mobile phone and notebook)Please help.
There are 5 Access Points WAP150 connected to PoE switch Cisco SG 350-10P and SG-110-24, there is ISP Internet Router giving speed around 70mbps over fiber, the case that the speed on data ports giving around 70mbps speed but on wireless access point...
Ok, so I have a set up of eight WAP 371 in single point setup, and four different wireless networks configured in each radio (4 in 2.4GHZ and 4 in 5GHZ). Problem is that after a few hours of work devices stop connecting to the AP's. If the radio is d...
Hi Everyone, Please Suggest us suitable WIFI Extender to Use with Aironet 1850 Series. This is for Big Palace where we have multiple WIFI Access point which has Same WIFI Signal. For Few Rooms we Have less WIFI Coverage so Planning to add WIFI Exte...
I have some trouble to cluster three WAP371 APs.
All three are up-to-date with the firmware 1.3.0.6. But when check the PID VID, one Access Point has a different one: Two are WAP371-E-K9 V03 and one is WAP371-E-K9 V02. I can cluster the two ...
Our network is mainly cisco devices with the exception of the Firewall The structure basically a MDF, IDF2 and IDF3. IDF2 and IDF3 connect to MDF by fiber independently. IDF2 has two switch (1x SG200-26P and 1x SF300-48P), three WAP581 connect to thi...
Was trying to update the firmware for a WAP125 to 1.0.1.7 and it failed and now won't boot. I want to flash to 1.0.1.5 from scratch. Is there a way to do this? BTW I see that 1.0.1.7 is no longer listed for download... I hope I don't have a brick bec...
I am working with a recently purchased Cisco Mobility Express controller, model 1815i, and in the Cisco Mobility Express Deployment Guide 8.5, on page 47 under the heading "Using customized internal guest portal" it states that if a customized guest ...
I just purchased 4 WAP571 APs to use as a cluster, 3 of them are working great, when the 4th is joined to the cluster any client that connects to it is unable to get a IP address from the DHCP server. If I reconfigure this AP to not be part of the c...
Hi,I hope someone can help I've been struggling to find an answer to this.We Bought 3x WAP551's recently but are having nothing but hassle with them. Half our devices won't connect or show low/weak signal even when only sat a few meters away. Other d...
I had 3 Cisco WAP571E Wireless Units Clustered from 2016 and working fine. One of the units failed (still looking to get that resolved), but couldn't wait and added a new 3rd unit just purchased. Updated the firmware of all to the most recent (1.0.2....
