Cisco 240AC Access Point
Bassam Addas
Cisco 240AC Access Point requires DHCP only??
can i assign static IP address to internal AP and management IP ?
5 Replies 5
Bassam Addas
Martin Aleksandrov
Hello Bassam,
Yes, you can change from DHCP and assign a static IP address to the Primary IP management interface (the IP address that you use to access the AP at ciscobusiness.cisco) also used to manage the cluster and also change to static the AP IP address. You will need to navigate to the Wireless Settings-->Access Points-->Primary Capable-->Edit-->General-->IP Configuration or -->Primary IP-->IP configuration
You mean herer right?
But i should also write DNS nummber but i dont Know where ?
Hi Martin
i tried but i can not save it
ther any one can help me?
