Cisco ax150 ver 10.6.2.0
DeltaEchoV
I am using 3 AX150 AP in the home environment (700sq.ft with 10-15 clients) and even with the default setting client keeps disconnecting and fails to do seamless roaming with FT enabled with wpa2. With wpa3 roaming doesn't even work.  Earlier I was using openwrt with wpa3 on an asus router, it worked with seamless roaming and no disconnection on the client side.
NOt at all happy with this AX150 ver 10.6.2.0. Not sure how it behaved for earlier version, because as per cisco you need to update to latest version for optimal operation.
I have not found reporting for 10.6.2.0 for ax150
marce1000
              >..   . With wpa3 roaming doesn't even work.
              - Check the AX150's logs when that happens ,
 M.
Yeah, apparently that is limitation of cisco. Because openwrt support wpa3
roaming seamlessly. I have checked log tried googling, searching on forum but nothing significant coming up in logs
And I have configured with wpa2 personal with FT enabled. AX150 is not at
all stable.. too many client disconnect.
Few logs snippet
*apfMsConnTask_0: Jul 04 17:53:33.790: %APF-4-RCV_INVALID_ACTION_CODE: apf_80211v.c:1928 Received invalid action code 1 from mobile station EA:5B:DF:E6:0B:0C
*apfReceiveTask: Jul 04 17:53:33.789: %APF-6-PROC_DOT11_MAC_MGMT_DATA_FAILED: apf_80211.c:17265 Could not Process 802.11 MAC mgmt Data from ea:5b:df:e6:0b:0c to 5c:64:f1:b2:70:6d - Invalid toDs/fromDs bit set - packet ignored.
*apfMsConnTask_0: Jul 04 17:53:13.998: %APF-4-RCV_INVALID_ACTION_CODE: apf_80211v.c:1928 Received invalid action code 1 from mobile station AA:81:D7:FD:2F:17
*apfReceiveTask: Jul 04 17:53:13.998: %APF-6-PROC_DOT11_MAC_MGMT_DATA_FAILED: apf_80211.c:17265 Could not Process 802.11 MAC mgmt Data from aa:81:d7:fd:2f:17 to 5c:64:f1:b2:55:cf - Invalid toDs/fromDs bit set - packet ignored.
*apfMsConnTask_0: Jul 04 17:51:33.790: %APF-4-RCV_INVALID_ACTION_CODE: apf_80211v.c:1928 Received invalid action code 1 from mobile station EA:5B:DF:E6:0B:0C
*apfReceiveTask: Jul 04 17:51:33.789: %APF-6-PROC_DOT11_MAC_MGMT_DATA_FAILED: apf_80211.c:17265 Could not Process 802.11 MAC mgmt Data from ea:5b:df:e6:0b:0c to 5c:64:f1:b2:70:6d - Invalid toDs/fromDs bit set - packet ignored.
*apfMsConnTask_0: Jul 04 17:51:13.994: %APF-4-RCV_INVALID_ACTION_CODE: apf_80211v.c:1928 Received invalid action code 1 from mobile station AA:81:D7:FD:2F:17
*apfReceiveTask: Jul 04 17:51:13.993: %APF-6-PROC_DOT11_MAC_MGMT_DATA_FAILED: apf_80211.c:17265 Could not Process 802.11 MAC mgmt Data from aa:81:d7:fd:2f:17 to 5c:64:f1:b2:55:cf - Invalid toDs/fromDs bit set - packet ignored.
*apfMsConnTask_0: Jul 04 17:49:33.789: %APF-4-RCV_INVALID_ACTION_CODE: apf_80211v.c:1928 Received invalid action code 1 from mobile station EA:5B:DF:E6:0B:0C
*apfReceiveTask: Jul 04 17:49:33.789: %APF-6-PROC_DOT11_MAC_MGMT_DATA_FAILED: apf_80211.c:17265 Could not Process 802.11 MAC mgmt Data from ea:5b:df:e6:0b:0c to 5c:64:f1:b2:70:6d - Invalid toDs/fromDs bit set - packet ignored.
*apfMsConnTask_0: Jul 04 17:49:13.997: %APF-4-RCV_INVALID_ACTION_CODE: apf_80211v.c:1928 Received invalid action code 1 from mobile station AA:81:D7:FD:2F:17
*apfReceiveTask: Jul 04 17:49:13.997: %APF-6-PROC_DOT11_MAC_MGMT_DATA_FAILED: apf_80211.c:17265 Could not Process 802.11 MAC mgmt Data from aa:81:d7:fd:2f:17 to 5c:64:f1:b2:55:cf - Invalid toDs/fromDs bit set - packet ignored.
