Hello!
This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful.
Virtual Assistant- Discover support content and options for your gearSupport page index - Contains a ...
Hallomy new accesspoint wap321 no access wlan devices.The log of WAP321 say:Aug 9 2014 20:53:44infohostapd[2002]wlan0: IEEE 802.11 STA 84:38:38:f5:8e:de deauthed from BSSID 24:e9:b3:bb:af:70 reason 3: STA is leaving IBSS or ESSAug 9 2014 20:53:44info...
There are two options to run the IR1833 in standalone mode: EWC (C9100 EWC AP bundle image ap1g8 17.11.1 (17.11.0.155) ) and WGB (Unified client image ap1g8t-k9c1-tar.17.11.0.155.tar)
In order to run it in WGB (to bridge a router interface via...
Hi,I have 5 WAP361 running and I'm happy with your product.4 out of 5 could be upgraded to firware 1.1.4.0 without any problem.The remining one stays at 1.1.2.4. I tried several times without success.I tried to upgrade to 1.1.3.2, but also without su...
Hi all, would really appreciate some help and guidance. have x5 CBW240-AC which I am trying to configure to broadcast a single SSID across a large area. I am not using mesh extenders and they will all be wired back to the core switch. I have configur...
Office has 5 Cisco Business 240AC access points that are providing good coverage for most of the office. There are 2 rooms that when the doors are closed lose the wireless signal completely. I ordered 2 Cisco143ACM Mesh Extenders to add into the net...
Dear Community,
I opened a new entry for better investigation.
My setup:
Cisco WAP581 with Version 1.0.1.3, connected to a Cisco SG250-10P through PoE behind an ASA5506.
Multiple SSID with multiple VLANs. 5GHz and 2.4GHz fully deployed without ...
Our building has four Cisco 140AC wireless access points. I have some test instruments with wired ethernet that I would like to connect over WiFi using ioGear GWU637 ethernet to WiFi adapters. The problem is that the 140AC will not forward DHCP ackno...
Hello Alli have been using WAP 321 AP quite long time. 3 APs are configured in single point setup.due to connectivity and speed issue i have changed the the mode to 802.11 (a/n) from 802.11(b/g/n)after that i observed all the lights on AP glowing amb...
I Have an install with 2 CBW240AC, 2 CBW141AC, and 1CBW143AC. Mesh extenders mainly used for hardwire connections. System has been working good for a couple years now, but in the last month or so all devices keep dropping and flashing red, yellow, an...
Hi - just signed up to the forums for some advice... I have a WAP371 which I do not have the correct wall mounting kit for I have searched the internet and I am really confused Can anyone assist here where I would find the correct replacement part as...
can the 240AC Access-Point be powered with a 3560CX-8PC-S Switch? According to the Data Sheets the 3560CX supports 802.3af and the 240AC 802.3af/at. So is this compatible?
Thanks for any help!
Hello, I'm new here, I recently bought a 240AC and am in the process of Configuring it. I have a cisco3560G switch that is connected to a Cisco 2911 Router. I want to set up several SSIDs for various vlans which I've already Configured on the 3560 sw...
~I have been struggling and failing to get a captive portal working on our 3 cisco wap150s.I think I have set it up in accordance with the admin guide but it doesn’t work. The relevant SSID appears that when clicked displays a dialog box saying “Ent...
Hello,I have 4 WAP150-E-K9-EU v02. The Software version is 1.1.0.9.I try configurate the Captive Portal with autentication local, but is imposible because when I put the Associate VAP (2.4 GHz) and Associate VAP (5GHz) and click SAVE, the configurat...
