Cisco Business 240ac Access Point
Bassam Addas
Hi!
I have Cisco Business 240ac Access Point
My question is can I connect AP with different switches or it must be available as special switches?
(For Poe Port I Can Fix Business Poe Injector)
You can use the Cisco CB-PWRINJ-xx power injector or a third-party 802.3af/at capable power injector to power on the CBW240AC AP.
Here is the PoE injector https://www.amazon.com/Cisco-Business-Ethernet-Protection-CB-PWRINJ-NA/dp/B087QTMJCN?th=1
5 Replies 5
balaji.bandi
AS Long as Switch support below spec to boot the AP, you can use any switch :
Powering options
●  802.3af/at Ethernet switch, a Cisco Business Switch with PoE is recommended
●  Optional Cisco Business Power over Ethernet injector (CB-PWRINJ-xx)
Power draw
●  13.2W
BB
can i use POE Injectoe which passa AP 240AC??
becasue my switch not support POE prt?
Powering options
BB
Bassam Addas
Hello!
I can log in Cisco 240ac from (https://ciscobusiness.cisco ) if I connect on the same WiFi and there is DHCP protocol.
but in another place, how can you log in Cisco 240ac Access Point without internet (without connection on the same WiFi) . I will install Cisco 240ac with in site that has static ip address so I need to log in and write ip address that applies.
