11-07-2023 10:00 AM
Hello all, I have a set of Cisco 240ac AP's that I am unable to access the web GUI from the device IP's or the management (cluster) IP. I have tried Safari, Chrome, Edge, Firefox, Edge in IE mode and IE itself with HTTP and HTTPS
I have tried to factory reset one of the AP's to see if I can start over, but I can't get it to reset via the small button on the back. When I hook up the console cable, I can see it boot and connect to the management IP of the AP's and continue on as normal. I can ESC during the boot and get to the BTLDR prompt but can't find how to reset the AP to factory. U-Boot version is 2012.07 (bltldr release 46).
I would like to change some settings and upgrade the firmware, but I am unable to do anything with them at this time.
Thanks in advance for your assistance.
11-07-2023 11:24 PM
>...that I am unable to access the web GUI from the device IP's
- Why not ? What happens when you try ?
M.
11-08-2023 08:35 AM
I get a can't reach this page in the browsers.
11-08-2023 08:58 AM
Sorry, didn't quite get it all in there.
Ports 22/80 are open on the AP's, but I can't login via SSH. I think it may have to do with HSTS getting in the middle even though I have tried to exclude it in Chrome, so still working through that aspect.
11-08-2023 09:21 AM
Not doing a great job here, port 80 is only open on the cluster manager, 22 is open on AP's, not the cluster manager. I fired up an old Windows 7 PC to use IE and it does not try to redirect to HTTPS and it cannot connect either.
11-22-2023 03:31 PM
Got it figured out, shutdown all the AP's, bring one up and erase it and then bring the others back online. Boom!
10-11-2024 12:00 PM
Podrias explicarme como lo resolviste tengo el mismo problema no puedo entrar ala interfaz de el AP, por cierto no aparece la red inalambrica dejo de aparecer en redes disponibles solo funciona por ethernet y no se deja reiniciar tampoco entrar en la interfaz
