% Invalid input detected at '^' marker.
F5MZE
Hi there,
Trying to access to the config terminal, I get error
Here is my process :
Login to my access point via ssh
login as :admin
Using keyboard-interactive authentication.
Password:xxxxxxxxxxx
AP>enable
Password:xxxxxxxxxx
AP#configure terminal
AP#
Any idea ? Thanks for helping
F5MZE
Finally find the solution, I have re-created the admin user of the AP from the WLC :
config ap mgmtuser add username <myUser> password <myPassword> enablesecret <myEnablePassword> <myApName>
and now, when I connect to my AP, I can run config terminal
Thanks to all for your help
20 Replies 20
Jagermaister
You can also try use conf t to go into configuration part
Thnks but doesn't work either
balaji.bandi
try config t  (same as you tried - but short cut see if that works?)
What is the model of the AP / IOS Code running  - is this registered with WLC ? or standalone mode ?
BB
Hi BB,
This is the Cisco Aironet 2700 Series (IEEE 802.11n) Access Point running Cisco IOS Software, C2700 Software (AP3G2-K9W8-M), Version 15.3(3)JA10, RELEASE SOFTWARE
Registered with WLC
If that is registered with WLC, you cam manage using WLC only you have less capability to change anything.
what is the reason you looking to use config t ?
BB
I want to define snmp community.
I can't define thru WLC
As i mentioned i dont believe you can do while WLC  based setup the APs do not support SNMP,
you need poll   WLC IP for SNMP.
BB
Have 19 AP WLC based with the same WLC and was able to do it on all of them except this one.
My real problem is I can't go to the 'Configure Terminal' environment on this one AP
Oh, you mean 18 AP device you able to config t and make config changes ? and 19th one you not able to change the config ?
what WLC ? Model and Code running ?
BB
Yes
WLC is Model 2504 running 8.0.140.0 version
Thank you for the input, i never had chance to access AP cli  while manging with WCL and Prime (i may be wrong, this may be be  possible)
Look at the config more :- compare with working with not working ? ( access point section)
https://www.cisco.com/c/en/us/td/docs/wireless/controller/8-0/configuration-guide/b_cg80/b_cg80_chapter_011111.html
BB
thanks for your link. Unfortunately, access is forbidden
Hi BB, this moning, the link rocks
Nice to know the Links works, Hope that help you.
BB
