CISCO CBW140AC
PauloGomes23234
Please, I don't have a POE switch, I need to hook up a CBW140AC using an RJ45 to POE adapter,
I need to know what voltage this adapter needs. Could someone please pass some information?
APs power draw is as below. you need to supply that power from injector. normal PoE injector will do the work. you cannot use power adapters for this AP.
https://www.cisco.com/c/en/us/products/collateral/wireless/business-100-series-access-points/smb-01-bus-140ac-ap-ds-cte-en.html
Power draw
●  8.3W (maximum, on PoE)
Good luck
KB
