Cisco WAP 121 guest network
Ziad Mohsen
Beginner
Beginner
Can any one tell me how to create a guest network in cisco wap121 AP With a time limit?
Martin Aleksandrov
Hello Ziad,
The WAP121 does not support Guest Network or the so-called Cisco Captive Portal. The only option is to configure a separate VLAN (VLAN to SSID mapping) for the guest network and assign a scheduler for that particular VLAN. This will allows configuring a rule with a specific time interval for VLAN (VAP) or radios to be operational. You can refer to section Scheduler in the administration guide for more detailed information: https://www.cisco.com/c/dam/en/us/td/docs/wireless/access_point/csbap/wap121/administration/guide/WAP121_321_AG_en.pdf
Martin
Recognize Your Peers
