Wireless - Small Business
Stay connected on-the-go with our Wireless solutions, designed for small businesses to boost productivity.
Don't miss this Cisco Catalyst 8000 offer
Labels
Update - We have completed the relabeling project for the wireless board. We will be lifting read-only mode today the Sixth of May. Thank you all for your patience and feedback.   We are approaching our latest step in relabelling posts across the Sma...
CoreyP319 by Cisco Employee
  • 593 Views
  • 0 replies
  • 1 Helpful votes
Hello!   This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful.    Virtual Assistant- Discover support content and options for your gearSupport page index - Contains a ...
  • 2838 Views
  • 1 replies
  • 5 Helpful votes
Hi, I'm trying to import an SSL certificate (pem file) to allow HTTPS inspection on my WAP121.When I try to upload using http upload I get the message "The certificate file failed to be uploaded".I could successfully upload that certificate on a MR33...
davidCPAS by Level 1
  • 689 Views
  • 1 replies
When our office closed, I brought home our Cisco WAP371 AC/N Dual Radio Access Point with Single Point Setup.  I am trying to install it to my home network which has a Netgear switch and a U-verse router with a U-verse extension WAP.  My present U-ve...
Bill_S by Level 1
  • 1134 Views
  • 4 replies
Gooed morning, i know some basics about networking and vlans, but i know setting up a cisco device can be sometimes challeging.i can buy a sg300-10 l2/l3 switch.my home situation is router, giving ip adresses through a small dhcp pool to all my devic...
I have setup this AP and successfully directed a new WLAN ssid to my windows RADIUS server and can connect a client OK, However my RADIUS attributes should also give the client a custom VLAN and it doesn't so I suspect there may be Cisco specific att...
Wrestling with these WAPs for almost a year now and the hopeful resolution, I believe, is contained in this thread—meaning wait for a firmware patch that's allegedly under active development.Countless other threads on 581s flapping, 'losing wireless,...
