10-09-2018 04:51 AM
I would like to schedule a reboot of my WAP 581. I check the box to schedule and set days and hours. It works the first time and never again for some APs. When I look at the settings after the first reboot, the "schedule reboot" is unchecked and the days & hours are set. Any ideas? Should I set at the command line or does it work better with a certain browser. Something so basic is not working !!!
10-16-2018 01:44 AM
Dear Customer,
What is the firmware version you are currently running on your WAP581? Here's a link to the latest image: https://software.cisco.com/download/home/286314835/type/282463166/release/1.0.1.3?i=!pp
10-17-2018 07:11 AM
Yes using the latest firmware.
10-18-2018 12:45 AM
Dear Customer,
Please send me a private message with your Cisco ID and the serial number of the device so I can open a service request for you.
If you don't have a Cisco ID, please register here: https://identity.cisco.com/ui/tenants/global/v1.0/enrollment-ui
Thank you!
10-18-2018 05:06 AM
