Wireless - Small Business
Stay connected on-the-go with our Wireless solutions, designed for small businesses to boost productivity.
Don't miss this Cisco Catalyst 8000 offer
Hello!   This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful.    Virtual Assistant- Discover support content and options for your gearSupport page index - Contains a ...
CoreyP319 by Cisco Employee
  • 2462 Views
  • 1 replies
  • 5 Helpful votes
Hi, we need desperate help right now, we provide SMBs with WAPs but the WAPs keep causing network outages.   We've tested this and got similar results with the WAP321s, WAP150s and WAP361s. We've even deployed them in our office and they have caused ...
Aloau by Level 1
  • 578 Views
  • 1 replies
I upgraded to a WAP125 and am having problems getting multicast working on it.  When I connect to a WAP131, I have no issues with multicast.   I have tried turning WMF on and off on the VAP, on the WAP131, the WMF option is not turned on.
sworswick by Level 1
  • 953 Views
  • 4 replies
-i have a issue that my WAP571 get unresponsive occationally.....  Cutting the power, and the following restart solves the situation, but are there a better solution for this issue?   I downloaded the support log and i found this line in every chrash...
runegjo by Level 1
  • 1513 Views
  • 5 replies
Cisco doesn't sell the mount separately, and I need one. Willing to pay a few bucks plus shipping. I've checked 3rd party sellers, hoping someone is doing an upgrade and willing to part with it if it's not damaged. I'm in South Carolina.
jalonj by Level 1
  • 1100 Views
  • 2 replies
I configured guest for my captive portal on my clustered WAP371s.  It worked but I had a problem when you roamed. Every time I roamed or switched WAP371s it would flash up the captive portal screen.  Is there a way around this?  What are the key sett...
Lee Cox by Level 2
  • 1185 Views
  • 3 replies
Hi everyone, I am trying to set up a WAP150 as a WGB. For my understanding the configuration is pretty straight forward, but it is not working correctly. I want the WAP150 to connect to one of our CAPWAP APs. The WAP150 connects as a client, but is n...
Snowhite by Level 1
  • 947 Views
  • 1 replies
Recently installed a new WAP 581.  When loading a video on wifi, I noticed it started to buffer.  I performed the same test on LAN, no issue.  When I performed a speed test on LAN, 60+ mbps download. Wifi test was 4-5 mbps.   Upload on both are almos...
