CISCO WAP4410N Access Point disconnect after a short while
ciscokasun
I got a CISCO wap4410n access point and it is disconnecting uses after a shorl while. I hv to again connect them manually. Please help me.
John Frankish
If you search these forums on the keyword "wap4410n" you will find many posts describing similar problems with the wap4410n.
Some or all of the reported problems might be resolved with a firmware update, but this update is not available yet.
It is possible to obtain a beta version of the updated firmware - search these forums to find how to do this.
