WAP2000 Wireless-G Access Point (Setup Help)
sam.stein3
We have a wireless-g access point typically (and previously, in this case) used for a small business. We were given the device for free and wanted to reset the device to use as our wireless router at home. First and foremost, can a wireless access point double as a home wireless router? I was told that only one computer/laptop at a time can connect to a wireless access point, unlike a wireless router which allows multiple devices to connect to a wireless home network at a time? Is this true?
Second, because the device is not new, we no longer have the setup instructions. Upon resetting the device (holding down the reset button for 10 or more seconds), we were unable to access the WAP2000 online setup page for a username and password. The device is being picked up by our macbooks and shows up in the Airport as "linksys-g." However, we are unable to access the setup page or communicate with the access point. We have tried typing http://198.162.1.1/ in our address bar, but have had no luck.
Do you have any suggestions as to how to set up the device? Also, can this device double as a router that will allow multiple laptops and devices (i.e. sony playstation) to access and use the wireless network simultaneously.
Thank you for your help.
jasbryan
Level 6
Level 6
Sam,
First yes you won't to factory reset the unit. You should hold down the reset button longer than 30 seconds and no longer than 45.Once this is back to factory default, the current ip address should be 192.168.1.245 , you will need to statically assign your pc an address in 192.168.1.1 /24 range and make sure you are plugged directly into WAP2000. Now you should be able to access the AP. Default username = admin password = admin
http://www.cisco.com/en/US/docs/wireless/access_point/csbap/wap2000/quick_start/guide/WAP2000_Quick_Start_Guide.pdf
Above is a quick start guide for reference.
Now just configure accordingly.
Jasbryan
Cisco Support Engineer
