Hello! This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful. Virtual Assistant- Discover support content and options for your gearSupport page index - Contains a ...
Dear @ all,I would like to know if I could build a "like Mesh" WLAN with some WAP4410N?In the way of:I-net <-LAN-> WAP4410N <-WLAN-> WAP4410N as Repeater/Client Mode <-WLAN-> 2. WAP4410N as Repeater/Client Mode <-WLAN-> ... ClientIs it possible?And ...
I would like to extend the wireless range of my rv120w, anyone have a solution that has proven to be consistent?Thanks,Mark
I was surprised knowing that RV220W does not work on 5GHz and 2.4GHz modes simultaneously (and this information was found only in the manual). So I'll have to buy one more device in order to have both bands working (one for 2.4GHz and one for 5Ghz). ...
Hi,Is is possible to integrate Cisco WLC with active directory using LDAP.Customer does not want to install any additional appliance(so radius is out of question).When client clicks on SSID, it should prompt for ActiveDirectory username and password....
Hello, I want to enable QoS on our Cisco wireless LAN controller in order to limit the amount of bandwidth that any single client can consume when using our guest network. I configured QoS on the controller, but when I visit speedtest.net I'm still s...
Hello.I have 3 AP541N. I become this not in a cluster. The APs standalone in the room. The first AP connect with cable to a DHCP Router from a other manufacturer. The other both APs should be connect over WLAN.How I must configure the APs? Which para...
Hi,I have a WAP4410N access point. In the datasheet, it shows that the Antenna Gain in dBi as 2. I need to increase the range of the access point by replacing the antenna with a 7dB one. I would like to know the maximum dBi supported by this access p...
Does Cisco WAP4410N work as repeater for Linksys E4200 ?Hi,i have Linksys E4200 and I need repeater for it ... Can anybody help me with this issue ?BR
Can the Cisco WAP4410N Wireless-N Access Point: PoE/Advanced Security Cisco Small Business Access Point use the Cisco Aironet Power Injector (AIR-PWRINJ4)?I know there was a Linksys Business Power Injector, but that was gone with the Cisco take over....
Hi, We have a wireless-g access point typically (and previously, in this case) used for a small business. We were given the device for free and wanted to reset the device to use as our wireless router at home. First and foremost, can a wireless acces...
I got a CISCO wap4410n access point and it is disconnecting uses after a shorl while. I hv to again connect them manually. Please help me.
i would like to know if wap200e will still have connection if there are trees in between. because we have 2 offices that is 200 meters apart and trees all over them. i just wanna know before we buy the unit.thanks
Hello everyone,Is it possible to connect two WAP200E on bridge mode without external antennas if they are 200 mts. (219 yard) apart?RegardsLuis Noriega
Hello,I am planning to buy an access point (WAP4410N) for a meeting room office ...According to Cisco technical documents indicate that the AP is the only work in mixed mode (B / N / G) and supports remote administration with console Telnet (most imp...
Hi all,we are looking on how to power a WAP200E. In the datasheet it mentions it supports POE, however the customer does not have a POE switch and for one WAP220E is not willing to purchase.What other options do we have? Is there a power supply for t...
