CISCO WAP4410N Access Point disconnect after a short while
RAHMATH.CK1
Dear Sir,
i bought one access point then we configured as Wireless Client/Repeater but wireless connection disconnecting and connecting  after a short while
i tried 4 more different ADSL and different  IP range ADSL model showing same.
so please advice on this matter ASAP.
Thanks.
Rahmath.CK
Eric Moyers
Level 7
Level 7
My name Eric Moyers. I am an Engineer in the Small Business Support Center.
I am sorry that no one has responded before now. What is the router that you are trying to repeat?
What were the steps you went through to do this?
According to the Admin Guide for the WAP4410N it will only repeat the WRVS4400N and another WAP4410N.
Eric Moyers
.:|:.:|:. CISCO | Cisco Presales Technical Support | Wireless Subject Matter Expert
Please rate helpful Posts and Let others know when your Question has been answered.
Hi Eric,
Please where (site, chapter) is this mentioned in Admin Guide for the WAP4410N?
thank you
My apologies I was thinking WRVS4400N when I recalled that. That router will only repeat to the WAP4410N and WAP2000.
For the WAP4410N, there is currently a bug on this issue.
https://tools.cisco.com/bugsearch/search?kw=Repeating&pf=prdNm&pfVal=282414137&sb=anfr&srtBy=byRel&bt=custV
I am afraid I inadvertently mixed the two together.
Eric Moyers
