Management Software
Van Johnson
I have several Cisco 541N WAP running in my environment which I manage with CCA.  I have now upgraded to Cisco 561N WAP, and I was wondering if there is a better management software out there I could use.
Looking for ideas.
Eric Moyers
Level 7
Level 7
My name Eric Moyers. I am an Engineer in the Small Business Support Center.
I am sorry to that you have not received an answer before now.
With the the WAP561s there are some internal features that you can use for the management of the devices. The best known is Single Point Setup. You can learn more about that in Chapter 10 of the Admin Guide: http://www.cisco.com/c/dam/en/us/td/docs/wireless/access_point/csbap/wap5x1/administration/guide/WAP551_561_admin_guide.pdf
A new edition to this feature is SIngle IP Management. With this you can access the cluster with one IP and manage the cluster from that.
Eric Moyers
.:|:.:|:. CISCO | Cisco Presales Technical Support | Wireless Subject Matter Expert
Please rate helpful Posts and Let others know when your Question has been answered.
