04-24-2011 03:37 PM
Does the Cisco WAP4410N Wireless-N Access Point device have simultaneous wireless N dual-band 2.4 GHz and 5 Ghz capability? Thank you.
04-24-2011 04:45 PM
No, unfortunately the WAP4410N supports 2.4 GHz only. If you want to deploy 802.11n with multiple access points, you really want to do with with 40 MHz channels in 5 GHz, and leave 2.4 GHz for 802.11g. As far as I know Cisco has no small business access points that support this.
04-25-2011 09:01 AM
Hi, My name is Eric Moyers. I am a Network Support Engineer in the Cisco Small Business Support.
That is correct, currently there is no small business product that supports both 2.4 and 5 Ghz at the same time. Also the AP541N is the only Small Business product that supports 5 Ghz currently. The reason for this is that our devices only have one radio in them. If you are looking for simultaneous support, I would suggest you look at some of our Enterprise devices.
They have several excellent products that support simultaneous dual band broadcasting.
Eric Moyers
Cisco Network Support Engineer
1-866-606-1866
