Cisco WAP4410N
JTDavisJAX
Does the Cisco WAP4410N Wireless-N Access Point device have simultaneous wireless N dual-band 2.4 GHz and 5 Ghz capability?  Thank you.
InternSupport
No, unfortunately the WAP4410N supports 2.4 GHz only. If you want to deploy 802.11n with multiple access points, you really want to do with with 40 MHz channels in 5 GHz, and leave 2.4 GHz for 802.11g. As far as I know Cisco has no small business access points that support this.
Hi, My name is Eric Moyers. I am a Network Support Engineer in the Cisco Small Business Support.
That is correct, currently there is no small business product that supports both 2.4 and 5 Ghz at the same time. Also the AP541N is the only Small Business product that supports 5 Ghz currently. The reason for this is that our devices only have one radio in them. If you are looking for simultaneous support, I would suggest you look at some of our Enterprise devices.
They have several excellent products that support simultaneous dual band broadcasting.
Eric Moyers
Cisco Network Support Engineer
1-866-606-1866
